Strange Problem with Nokia
2 replies · 1,754 views · Started 16 April 2005
Hello People my name is tarang i stay in india just few days back i bought a nokia 9500 communicator and i am facing a certain problem. I installed the cable drivers and the pc suite supplied by nokia in the package itself
The problem is that when i try to transfer a file i.e. a movie file size approx 100 mb it says the target drive does not have enough space whereas i have ! GB memory card and it says 970 MB free in the communicator.
I tried doing the same thing on my nokia 7610 and i am having 512 mb memory card in the 7610 and 130 mb is free in the 7610 and again i get the same error as the target drive does not have enough free space
Plz help me out with the solution to this problem.
Thanks in advance
Regards,
Tarang
Hm.... 9500 internal memory only 80 MB . . so if u trying to send the file into your phone memory . . for sure it will prompt out that the disk space is not enough . . try to send the file into ur MMC or use card reader to transfer the file into ur MMC. . .
