GDB Debugger - P800 GDBSTUB needed!!
0 replies · 1,871 views · Started 17 April 2005
Hey Everyone
Am in dire need of on target debugging, with GDB Debugger or eqv. for the P800!
I have most of the files required for this, which came with my SDK (UIQ 2.0 - Update 1), but am missing gdbstub.exe (apparently, in some cases comes pre-loaded on the phone, but not in my case) which needs to run on the P800.
This program, nor it's source came with the SDK. The only thing close to the GDBSTUB.exe I need is gdbstub.sis which I found in the SDK for series 60v2, which of course does not work for my environment (P800).
I have have thoroughly searched the internet looking for this program or it's source for my environment but to no avail.
The GDB debugger Source is supposed to be available from the symbian website,
at: http://www.symbian.com/developer/downloads/tools.html#gdbv70,
for the file: http://www.symbian.com/developer/downloads/files/make.004.src.zip , but the file appears to be broken. Not allowing decompression in Windows (winzip) or in MacOSX.
Once downloaded, all i can do is view the contents of the file, and winzip does not allow decompression, giving the error:
Error in file #1: bad Zip file offset (Error local header signature not found): disk #1 offset: 0
Error in file #2: bad Zip file offset (Error local header signature not found): disk #1 offset: 134
....etc.
I would greatly appreciate getting this gdbstub.exe, either a binary or source, or the fixed GDB installation software package.
Any help given would be thoroughly appreciated.
Thank you for your time.
Matt
