nokia 6630 email
3 replies · 2,023 views · Started 17 April 2005
hi folks, im trying to sort out me email problems. I have been in touch with orange about this and they are as much use as a chocolate tea pot. I am able to recieve all my email but for some reason i cant send them, ive checked my settings and user names. All are ok, i keep getting a mail return email, which i can download from orange ???? does not make sense. Any ideas
For your outgoing (SMTP) mail server, are you using your ISP's SMTP server or Oranges?
If your ISP's, use Orange's.
Check also whether it requires authentication or not, and whether it requires a secure (SSL) connection or not, and change the settings accordingly.
Orange can you send you the settings through their mobile website or their normal website.
fdxd wrote:Orange can you send you the settings through their mobile website or their normal website.
I am able to recieve but not sent as well. I have found out the problem is my incoming mail requires the security port to be set to 995 and the outgoing mail needs security ports in off made so I have to change it each time I want to send or recieve mail.
I would be interested to hear from anyone who is using an email program other than the one provided by nokia to see if the incoming and outgoin settng can be set independently on other programs.
