9500 problem
3 replies · 1,826 views · Started 18 April 2005
Hello friends i am having a nokia 9500 communicator. The problem that i am facing is that when i use the communicator interface there are 4 buttons to the right and sometimes these buttons work and sometimes these buttons do not work and when i bend the screen so that i can read properly at a proper angle only the upper 2 buttons seem to work fine otherwise the below 2 buttons do not work at all and then i have to move the cover down again as if i am closing it and then the uttons work fine. Is this normal with all the communcicators or am i been given a dud piece.
And also is there a way that i can make the communicator opening interface tight as it has become loose
and plz let me know what is the latest software version for the communicator and whats the difference between 4.44 and 4.51 version of software for the 9500 communicator
Thanks in advance,
Regards,
Tarang
Hmmm, what a coincidence in timing! I posted the answer in the message thread just before yours: SCROLL KEY NOT PRECISE ENOUGH?
Takes 1 minute to fix, once you have the correct washer.
Good luck - and no warranty.
tarang wrote:The problem that i am facing is that when i use the communicator interface there are 4 buttons to the right and sometimes these buttons work and sometimes these buttons do not work and when i bend the screen so that i can read properly at a proper angle only the upper 2 buttons seem to work fine otherwise the below 2 buttons do not work at all and then i have to move the cover down again as if i am closing it and then the uttons work fine. Is this normal with all the communcicators or am i been given a dud piece.
You've gotten a dud I'm afraid. Take it back.
I agree with Raven...
The rocker switch on my 9500 works perfectly & I've never had it miss-select.
Xoio 'Al'
