few doubts
27 replies · 2,897 views · Started 18 April 2005
hi guys,
got my hands on sendo x....a very cool phone & lots of featuers...getting to like it... 😉 ...but i have some doubts...
1) i have stored some ringtones in wav & in mid format into my phone...but i cannot delete it...so how can i delete them?
2) how can i play *.avi & *.rm files on my phone.the phones real player plays only 3gp files..is ter any application tat plays other video format?
3)i have configured my gprs...but i cannot connect it to my pc as modem through infrared...is ter any procedure 4 tat??
would b of great help if u guys help...thx in advance....take care all!
1) You will need a file manager app. to delete the files. Fileman from GoSymbian is free and excellent.
2) Smartmovie will play .avi files. I'm not sure about .rm, but you could try the free Helix player (next version of Real Player), or convert the files to .3gp on a PC first.
Oops, yes, I did...sorry.
There's one called FileMan as well (think symbiango do it) - I have both installed on my phone and just got the names mixed up... 😞
Koso - check out this section from a very experienced Symbian user:
http://3lib.ukonline.co.uk/viruses.htm
Do not bother with antivirus - it is a waste of time. What's not a waste of time though is an app called TaskSpy - Keeps track of open apps and can allow you to close down things at will. Its freeware - go get it.
hey thx masamune...tat site really makes sense...but under infection can simply formatting will do the trick...does it?
& wat bout the modem interface guys..anyone have any idea..the problem is i can connect the sendo x's modem with my pc through ir connection but wen i dial up it says "the port could not open as another application is using or ter may b some error with modem configuration"...wat could b the problem?
Hmm...it could be your GPRS settings on your phone - your best bet is to use the OTA configuration on Sendo's website. I rarely use my phone as a laptop modem as it really, REALLY eats into your phone bill. If its just for web browsing and whatever, stick with Opera on the sendo itself.
As for viruses - the media loves it when a new virus appears - it makes for great scare stories, which of course sell papers. The only Symbian viruses I know of were done as proof of concept - i.e. they were created under test conditions and then sent straight to an antivirus company. I would safely say that you are more likely to get struck by lightning and then a meteorite than get a Symbian virus. Provided you aren't using software from "dodgy" suppliers (you know what I'm talking about), then your phone will never, repeat, never get infected.
Masamune wrote:Hmm...it could be your GPRS settings on your phone - your best bet is to use the OTA configuration on Sendo's website. I rarely use my phone as a laptop modem as it really, REALLY eats into your phone bill. If its just for web browsing and whatever, stick with Opera on the sendo itself.
yup my gprs configuration is working & i can access the web with my sendo but i cannot use it as a modem....tats the problem!!!
and ters a problem i think with my phone....wen i charge my phone wen its off it does not show the charging animation but displays the sendo start screen and blinks with tat screen on & off...wat could b the problem?
kosmonov wrote:and ters a problem i think with my phone....wen i charge my phone wen its off it does not show the charging animation but displays the sendo start screen and blinks with tat screen on & off...wat could b the problem?
I had this problem. It was an application (fs caller? don't know) that can display the picture of who call's.
I've uninstall it and it worked!
Hope that helps.
The exact same problem I had - I'm trying to track down an earlier version - apparently v3.13 worked OK. Stuclark said he'd send me a copy.
cool....may b i'll seggregate my mobile from such crappy applications ...i dont wanna ruin the phone eventually...may b i should b happy with wat i have... 😊 .... & one more thing ...i can use my sendo-x as a modem too ...😊
Oh - you got it sorted? Post up the results so if anyone else has the problem, they can sort it out as well.
giv me some time dudes....i'll test out the remaining craps & post it out...will b a great help 2 others...😊
& one more thing...wats the maximum amount of memory card does sendo-x support? can it work with 512 mb cards?
kosmonov wrote:& one more thing...wats the maximum amount of memory card does sendo-x support? can it work with 512 mb cards?
Sendo informed me a while back that they have tested most cards including ones up to 1GB so you should be OK!
The X and X2 support up to 2GB memory cards. My X has been running on a 1GB card for a long time with no problems, and I know that at least one person at Sendo is using a 1GB card in their X2.
