Can someone help me on my 3650?
6 replies · 1,801 views · Started 18 April 2005
Well, it's the 1st time i'm in here...
anyway, i have this 3650, and i regret i bought it. about 2 months ago, there was a kinda system error, and on start up it said "main. app closed", and the menu button didnot work at all. some other applications opened via favourites didnot work either... some system error.
i got it reflashed... and now again.. the 'pen' button is not working... cant write sms...well cant write text at all.. cannot switch from number mode to alpha mode...
and also, its not entering general settings... says app closed...
can someone suggest me wut to do, and wut not to do in order to not get such problems in the future??
appreciate any ideas!
..... here in the forum found out that by *#7370# it possible to format it.. will try it now..... hope everything's gonna be okay...
Did you, by chance, install the WildSkinz app on your phone? It will definitely cause some of the behaviour. Search for "WildSkinz" to read more: http://www.allaboutsymbian.com/forum/search.php
In any case, a reformat with *#7370# should clear also that up (you will need the phone's lock code for that; the default is 12345, if it hasn't been changed).
Yeah, actually i installed wildskins... is that because of that??
i tried *#7370#.... everything was fine, but the memory card... i use 64mb multimediacard, and it was not found... and i turned the phone off... and again on, but its not switching on.. just the logo 'NOKIA'.. and after about 6-7mins it says 'app closed phone'
now i guess its even worse... damn nokia...
can someone suggest me wut to do!?!?
appreciate,
!�K�
Format also the memory card (especially if you installed WildSkinz on the memory card).
thanks a lot.. i've found lots of useful staff by searching...
god damn WildSkinz...
well, can i at least use the sLauncher...or whatever it is... the skin changer application for nokia 3650?? is it safe?? or is there any other progs to change skin.. or themes??
thanks a lot!
!�K�
thanks man, appreciate!!
i'm glad i entered this forum.
hopefully i won't, but if i have any problems in the future, i know where to get solution😊
N/A, u r the man!
