Does anybody know why I'm getting
"Error: Unable to load code and data size" message when I try to build a project in codewarrior with UIQ 21. SDK in ARMI_UREL.
I get this message for some .cpp files but not others in the same folder. Some files from the same source directory compile without any problems. I'm using the Stationary Simple Application give in the UIQ 2.1 SDK and added a couple of my own .cpp files.
Do I have to change someting in the preferences or the paths?
I would appreciate any help.
Thank you.
