Today i brought the TDK USB adapter but when i go into the connect menu then press bluetooth it just comes up with "Bluetooth- System Error" ive tried reseting the phones settings but still doesnt do anything, i know its worked before because ive connected to another 7650 but it wont even go into the bluetooth menu this time,
Cna someone help?
Big Bluetooth Error Advice needed plz
PPl with similar problems had to go to the NSC and either have their phone replaced or sent away for two weeks and got it back!
damn thats annoying but it worked before, i connected with my dads 7650 its just all of a sudden
This is sometimes tha case when using filemanagers and deleting files. But It could be a hardware or software fault! My advise is to return the phone. Its anoying but this might be the best choice! Who knows, you might be lucky and get a new phone 😊
Well good thing i took out Orange Care thanks for your help if anyone has anymore advice plz let me know
I have the same problem too.. :cry:
same problem here!
went to a NSC and they flashed my phone to 3.16. Problem has gone, but I've read that people with the new firm hav this bluetooh bug too.
�$%$"$ Nokia! We are not beta users.
Same here,but my device allso expirienced a battery fatigue problem,i had to recharge in less then a day,its still in Germanys NSC,my advice is,you do the same,take it for repair.
Same problem here. the BT wont work and I am suffering a battery fatigue problem. :evil: If you ask me Nokia phones are quite buggy! Still they are feature rich 😉 I think I will have to get the rom upgrade.
Also what is the reset code again???? I might try that first.
*#7370#
