Hi All
Has anyone else noticed that the fields in the default contact cards are in a funny order? When I create a new card the address fields appear as:
Street
Postal Code
City
State/Province
Country/Region
I can't rename the standard fields or re-order them when changing the default template?
Do you have a logical order (Street, Area, City, County, Post code?) did you have to create a card from scratch?
Also when editing a contact when you add an address field all the fields are added rather than being able to pick and choose which ones. If I then delete a field and then try to re-add it it is greyed out!
Any advice?
Cheers
Jago
