is it possible to add a reset app. to the menu.how can i do that or is there any app. can do it?
reset app.
U mean an application to reset phone to factory setting? If yes, u can use speed dial or u can ask for it at symbian or symbian developer. 😊
not reset to factory settings!sometimes i need to restart my n-gage its difficult to close it and open it again and enter a pin code..i need a quick one, an applctn that can restart phone like my n-gage does sometimes itself when i drop it or install any program etc..
There are many apps that can restart ur phone. Like file explorer (FExplorer-gosymbian.com), appman and sysman (symbianware.com). With sysman, u just hold ur menu button, point to ur phone then press C then 'yes' twice.
