Easy peeps, new here so soryy if i'm covering old ground - did do a search to no avail tho.
I've installed Nokia PC Suite on me PC and have connected my 6630 up to the PC via Data Cable, however, whenever i try to do anything eg. transfer files, i can't, because my phone is not showing up on screen (Not recognised).
Any idea why its not picking up my 6630 ??
You need to install the dku5 driver mate. However if you install the latest version of PCSuite you will avoid that.
No! The 6630 does *NOT* use the DKU-5 (or CA-42) cable. It will work with the DKU-2 cable and the PC Suite installation (since v6.4, if my memory serves me right) should be installing the DKU-2 cable driver ("Nokia Connectivity Cable" driver), if it isn't already installed.
Anyway, to make sure, uninstall PC Suite and then in Control Panel's Add/Remove Programs uninstall also the Nokia Connectivity Cable Driver.
Then get the latest PC Suite from http://www.nokia.com/pcsuite (v6.5) and install it.
