keylock nokia 6670
1 replies · 2,604 views · Started 20 April 2005
I�m New With Nokia 6670 , I Have It Almost Two Days But I Still Can�t Find Out How To Lock It Or To Find Auto Keylock, Or Even How To Change Background Image.
Can Someone Help Me? Pls
Locking the keypad:
- press the left "soft key" and then the '*' key
- or a short press of the power key and then select the appropriate option (if you continue with short presses of the power key, the selection changes and then a long press takes that choice; i.e., you can do it by only using the power key).
Autolocking:
- In the "Settings" app's security settings part you can set the autolock period (unlocking will ask for the phone's lock code, which default is 12345).
You can also install apps such as JJLKeyLock and others to do the keypad locking via a timer (e.g., after 30 seconds of inactivity): http://my-symbian.com/7650/applications/applications.php?fldAuto=650&faq=2
For changing wallpapers and themes, use the Themes app (read more about it in the phone's User's Guide). Free downloadable themes: http://www.symbianthemes.com/
