Retrieving pictures from memory card issue...
3 replies · 2,214 views · Started 20 April 2005
Hi there everybody, i hope you can help me.
I have had this phone since february, and have been happily connecting it up to my machine and removing the pictures using nokia phone browser.
However, recently there has been a weird issue. I can access every single folder within the phone and memory card apart from the pictures folder in the memory card, so obviously i can no longer retrieve my pictures. I have formatted the memory card, and this rather odd problem is still occuring.
What could have caused this? How can it be fixed?
Any feedback would be greatly appreciated
Regards
Steve
Hi guys, first post here so hello to everyone.
Unfortunately i'm having the exact same problem as Steve here. I have a terrible feeling it is a virus of some sort (not very tech so how i got it i do not know, though i do have the odd bit of crap installed on my 7610 courtesy of my friend im choosing to now blame) but will be in a lot of trouble if i have to format it or something along those lines, as i have some very important pictures i cannot lose on my card (yes i know i am an idiot for not backing up regularly, i DID backup just not often enough).
thanks in advance for any advice!
gustav
Do you have a PC-based memory card reader? I had a problem like that on one memory card a few weeks ago, but I was able to copy all my pictures off the card to a PC with a card reader, and then reformat the card. I still don't know what happened with that card, but at least I didn't loose anything.
Hi, Thanks for taking the time to reply.
I don't personally have a card reader, I just use the cable that came with my 7610 to attach it to my pc (USB). Perhaps I should investigate buying one, thankyou for the advice.
Can anyone else offer any other solution?
thanks man.
