Hi, iv got a problem with my Nokia 6630. When i am at the messages menu, in less than 5 seconds it comes back automaticly at the main screen, without doing anything. Does anyone know why? any app can do this cos of a bug? help plz.
6630 Msg problem
It shouldn't be doing it. Have you installed some apps that do, e.g., background message processing (timed SMS, or something)?
What apps have you installed on your phone?
If you uninstall them one-by-one, when the problem disappears, you know what caused it (if it was any such app in the first place).
yes i think it is an app, cos when i format it , the problem dissapears so i think it was obvious, im so stupid, thx, ill try one by one.
