Can I install two version of PC Suite?
6 replies · 2,327 views · Started 21 April 2005
Because I would still like to be able to backup and sync my 6600, but the 6.5 version says it will not support 6600 and will nedd it for my 9500. I still have Psi Win installed for my Psions, so I am not worried about sis file association conflicts.
Thanks again for any help to this new 9500 owner
Yes you can install PC Suite for N6600 and PC Suite 6.5 at the same time. These two versions are not in conflict.
lakeywhite wrote:Thanks very much, I will now go ahead and do that. :icon14:
Just don't forget that PC Suite for N6600 connection module is mRouter, and PC Suite has another Connection module. Each of them has its own icon on the tray.
After installing PC Suite 6.5 my bluetooth connection for the 6600 stopped, so I can put the 9500 in the cradle and do everything for that but now I can't do anything for the 6600.
You cannot have two active BT connections to PC Suites at the same time. If you have BT link active in PC Suite 6.5 connection module, then switch it off in mRouter, and vice versa.
The same goes for IR and cable.
