I created a Choicelist and customised the command buttons in a dialog from resource file.
When i select a particular item, the command button's text should be updated dynamically.
For eg:
When i select item 1, the command button's text should display "Item1".
When i select item 2, the command button's text should display "Item2".
I have written the following code. It is crashing in the handle->SetControlCaptionL(ELoginPwdChangeBtn, KItem1);(highlighted area in the code😊
//CLoginPwdChangeDialog is inherited from CEikDialog.
void CLoginPwdChangeDialog::HandleControlEventL(CCoeControl* aControl,TCoeEvent aEventType)
switch(aEventType)
case EEventStateChanged:
//CCoeControl* control = this->Control(ELoginPwdChoiceList);
CEikChoiceList* list = reinterpret_cast<CEikChoiceList*>(aControl);
TInt index;
index = list->CurrentItem();
CExampleAppUi* appui = (CExampleAppUi*)(CEikonEnv::Static())->EikAppUi();
CLoginPwdChangeDialog* handle = appui->returnLoginPwdHandle();
//CCoeControl* control = static_cast<CCoeControl*>handle->Control(ELoginPwdChangeBtn);
//handle->dummy();
//CEikCommandButton* button = reinterpret_cast<CEikCommandButton*>(control));
if(index==0)
_LIT(KItem1,"Change Password"😉;
//button->SetTextL(KItem1);
iEikonEnv->InfoMsg(KItem1);
else if(index==1)
_LIT(KItem2,"Change Numeric"😉;
handle->SetControlCaptionL(ELoginPwdChangeBtn, KItem2);
//button->SetTextL(KItem2);
iEikonEnv->InfoMsg(KItem2);
else
_LIT(KItem3,"Change Symbol"😉;
handle->SetControlCaptionL(ELoginPwdChangeBtn, KItem3);
//button->SetTextL(KItem3);
iEikonEnv->InfoMsg(KItem3);
//CExampleAppUi* appui = (CExampleAppUi*)(CEikonEnv::Static())->EikAppUi();
//appui->ChangePwdBtn(index);
break;
RESOURCE DIALOG r_login_pwd_change_dialog
title="Login/Password Selection";
buttons=r_login_pwd_change_buttons;
flags=EEikDialogFlagNotifyEsc;//|EEikDialogFlagNoTitleBar;
//margins = r_response_margins;
//flags=EEikDialogFlagWait;
items=
DLG_LINE
type = EEikCtChoiceList;
id = ELoginPwdChoiceList;
control = CHOICELIST { array_id = r_login_lists; };
RESOURCE DLG_BUTTONS r_login_pwd_change_buttons
buttons=
DLG_BUTTON
id=ELoginPwdChangeOkBtn;
button=CMBUT { txt="OK";};
DLG_BUTTON
id=ELoginPwdChangeBtn;
button=CMBUT { txt="Change Password"; };
Regards,
Mani.
