Hi all u "Guroos". I have a problem that causes me to be very very angry as it has caused me nothing but trouble. I need one of you really smart intelegant guys out there to give me one answer that will fix my problem without all the bullshit downloads and crap.
I have a Nokia 6600 phone (sorry)
I have a Laptop.
I have installed Nokia data Suite that came with my phone.
I have a PCIMIA Billionton Bluetooth card installed and working. (sorry)
Nokia suite works just fine so does my bluetooth. I can do all these wonderful bullshit things with it EXCEPT I cannot update my address books!!!!!!!!!!!!!!!!!
Without this working I may as well through the phone in the bin and the laptop. I NEED THIS TO WORK AND WORK WELL.
If I update my address book Nokia data suite connects just fine but it will not update any changes. If I delete my address book entries on the Lapy and update the phone will only send 37 addresses and that is it?????
I used to use a infra red card and it worked fine. Change a number on the phone or Laptop it changed both to suit. NOW after I updated to Microsoft SP2 ets it will not work with either bluetooth or Inr.
Any smart person out there able to FIX this issue? PLEASE PLEASE!!
Has anybody got any suggestions that will fix this problem? Is it WinXP SP2 or bluetooth or Nokia data suite?
Nokia and Bluetooth Nightmare
oakey45 wrote:Hi all u "Guroos". I have a problem that causes me to be very very angry as it has caused me nothing but trouble. I need one of you really smart intelegant guys out there to give me one answer that will fix my problem without all the bullshit downloads and crap.
I have a Laptop.
Any smart person out there able to FIX this issue? PLEASE PLEASE 😉
Oakey,
I don't have any experience with sync and the 6600.
You could always try OTA synchronization through a SyncML Server such as MightPhone.
Best of luck.
Richard
dgduris wrote:Oakey,I don't have any experience with sync and the 6600.
Best of luck.
Richard
🙄 I have tried All the usaul fixes but with no luck. If I try other software I have even bigger problems. Nokia Data Suite and my bluetooth works great without any problem. It is just the sync problem I need to fix.
Bluetooth gave me massive problems and I have got it to work using 3 different dongles as well as the PCIMIA card and all of them work well except for this sync headache. Thanks mate.
