2 easy problem in bldmake and vc6 -please help-
2 replies · 2,528 views · Started 22 April 2005
hello,
iam very beginner in programming for symbian but i have 2 problem i think they will be easy.
1st one-----
i install sdk2 with symbian v 7 and after that i go to the command window then i enter to the folder which it contain bld.inf file in example folder"helloworld" and the i write"bldmake bldfiles" an error appear is "'perl' is not recognized as an internal or external command,operable program or batch file." then what is the solution?
2nd one-----
i install visual c++ 6 and i copy AvkonAppWiz_v20.awx and avkonappwiz_v20.hlp to c:\Program Files\Microsoft Visual Studio\Common\MsDev98\Template to make a wizard but after i start the wizard andafter i finished it to start the code window error appear say"c:\symbian\7.0s\epoc32\build\example\group\example\wins\example.dsw the specified could not be insterted into the current workspace" and then anther error apper say "failed to open workspace:0x8004a004"
please what is the solution?
thanks for all
hi,
Regarding ur first problem it seems u have not installed active-perl 5.6.1.
Have a nice time,
Regards
Chandra Prakash
Mohamedwaly wrote:hello,
1st one-----
2nd one-----
thanks for all
the 1st problem is solved but the 2nd not yet
i have 2 sdk one for symbian 6.1 and the anther v7
and i compiler helloworld example and it work in emulator and when i install it in my nokia 3660(symbian v6.2) it not work
then whic version of sdk that will work in most of nokia mobile series 60?
