Transfering files to the 9300 via Pc Bluetooth
3 replies · 3,065 views · Started 22 April 2005
ok im facing this weird problem.
When i transfer any file from my Pc to 9300 via bluetooth it straight goes in c:\communicator\My Files
whereas it is supposed to be in the Inbox with a message asking me where to save it.
Ive tried all the settings also control panel > connection > bluetooth , there is no option for target folder.
kindly help.
Thx
dj_insomniak wrote:ok im facing this weird problem.
kindly help.
Thx
It is the same for me on my 9500. So I suppose this has changed from the previous versions.
But why don't you use the file manager of the PCSuite? Then you can decide where you want to put the files.
upponalle wrote:It is the same for me on my 9500. So I suppose this has changed from the previous versions.
what file are you bluetoothing?
Isnt it better, series 60 puts it in the inbox but if you forget to save the file, you lose it. Just program the 'My Key' to 'File Manager' and stick it where you want. Seeing as the communicator has much more memory, I think its alot better than stuffing up your inbox 😎
