Contact File transfer
3 replies · 7,362 views · Started 22 April 2005
Can anyone pls help me on this. I currently got my 6260 and when i was trying to transfer my contact file from my 6610, I always get an error using the pc suite 6.5.10 ver. I notice that files from 6610 are ncc files while 6260 files are read nfc files. Is there an aplication to convert ncc to nfc. I tried outlook sync but didn't like the feature of it when i open my contacts, besides when i receive mms or calls the name doesn't register. Tried sim swapping also but my contact file is too large for the sim to handle. What is the best to transfer my contact files from 6610 to 6260. Plssssssssssssss help.....I'm very desperate already to use my 6260. Thanks!
Just a thought, since this works with SE 900/910.
Is it possible to store the whole Contacts file in one large vCard.vcf ?
Then you should be able to beam it over directly from the 6610 to the 6260 without using the PC.
This is what I normally do between my P900 and my Psion.
gema wrote:Can anyone pls help me on this. I currently got my 6260 and when i was trying to transfer my contact file from my 6610, I always get an error using the pc suite 6.5.10 ver.
Yoy can use Content Copier in PC Suite 6.5.10 - but it gives you error? Just go to the Backup'n'Restore, don't backup the N6610, but select copying data from the phone to PC, and transfer data. Then connect N6260 and get data from PC to the phone. Still error? Your N6610 contacts database may be corrupted, then.
gema wrote:Is there an aplication to convert ncc to nfc. What is the best to transfer my contact files from 6610 to 6260.
There is the conversion tool from NCC to CSV (Contacts Converter).
The result CSV file is in the format suitable for Contacts Manager.
For importing it into the N6260, you will need to get Contacts Manager for Series 60.
