VPN to Cisco PIX
2 replies · 17,387 views · Started 22 April 2005
Someone has tried to use Nokia VPN Client (on Nokia 9500) to
estabilish a vpn with a Cisco PIX 515 ?
I have an error when i try to make a new connection:
"Unspecified error, source 'Acu', error code - 102020, state code 6"
thanks a lot
Marco
sahli wrote:What VPN CLient are you using?
The original post clearly says pretty clearly "Nokia VPN Client (on Nokia 9500)".
marco-l79 wrote:...
Do you have a Nokia Security Service Manager server? Without it, the Nokia VPN Client cannot currently be configured to work with any VPN gateway. If you have it, then the VPN policy is perhaps not installed or correctly configured (whether it is or isn't is hard to say, without more details). Also, I have no info whether the VPN client (even if configured properly) supports Cisco PIX 515. It should support Cisco 3000 boxes.
