A925 hidden files
2 replies · 2,249 views · Started 22 April 2005
Hi!
Does anyone know how to view hidden files in A925 on PC ? In my mobile I use File Manager where all files can be seen , but on my PC they are not displayed, I just wanted to edit some system files to enable ringing+vibrating, but cannot find those files.
Thanks!
Palcho wrote:Hi!
Thanks!
This sounds like software that I played with a couple month ago, can't remember then name.
When I did, I used the Filemanger on the A925 to copy the hidden file ( drives ), to my SD card.
Then I could see / edit them. I even managed to get the startup and shutdown video.
The only thing I couldn't do was update the hidden files. I suspect that is because they are in ROM.
Ofdan
