I installed almost all soft but can't run...
Any idea ? which app. can do it.
Could to elaborate on what applications, exactly, "almost all soft" are?
There are probably a few thousand applications you could conceivably install on a Series 60 phone like the 3230, and if you don't say which of those you have installed, we have no way of knowing.
At least I haven't perfected the art of mind-reading, yet.
It might also be a good idea to explain what, exactly, it is that you want the applications to do (I don't know what you mean with "can burst mode or spying" and I suspect there are others that don't know either).
And it wouldn't hurt to say what "can't run" also means (what happens, exactly & if there are any error messages, you should also say what's in them, word for word as you see it displayed).
Okey .... here is the list (of not worked at all)
Timedspy 1.0
Spy 6600
Photospy
Imagespy 2.04
Photorite SP 5.18 (now i'm using 5.16)
Snapshot 7610
Any idea ? Please recommend
And "not worked" means notthing happened after run it at all ...
but about snapshot 7610 It can run but can't save the photos phone hanged when saving 1/6 (Take so long time and nothing happen no saved picture)
