The 6260 turn off and not work
2 replies · 1,619 views · Started 25 April 2005
I have installed a file manager software and i see the telefon directory: I have the folder "C" "D" "E" and "Z", I have explored "C", "D" and "E", when i Click to "E", the device turn off and don't function later. HELP ME !!!
The E-drive is the memory card. Which file manager did you install (FExplorer from http://www.gosymbian.com or something else)?
Do you have anything stored on the memory card? Is it OK when you view the content on the memory card with built-in apps like Gallery & others?
The problem could be a bad memory card combined with a bug in the file manager you installed or just a bug in the file manager.
So, try with the memory card removed.
Sorry, the problem is of the battery that is not charge..... thanks for help !!!
