I bought a 6600 cover, but I have no idea on how to put it on, any instructions?
Thanks. 😉
Thanks. 😉
ya need a special screwdriver n something to pry the front cover off.you can find the tools on ebay or take it to a phone shop which might be able to do it.it'll void your warranty though so some shops might not
no screwdriver is required, just some patience.. start at the bottom and push a creditcard inbetween the chasis and the fascia, this should lift a little, then just slowly work yer way around the entire fascia. If you cannot get the card to push into the bottom then you can find two small holes beneath the battery cover, one on the left and one on the right. just push something long and small down these and it will cause the fascia to lift a little. :icon14:
