Hi all,
I have had my 7710 for about 6 weeks now and it has already been replaced.
I have my music stored in I tunes in my laptop. I cannot find a way to tranfer onto my phone.
The guide doesn't help me.
Can any of you??
Smulsh
Malaga, Spain.
Hi all,
Can any of you??
Smulsh
Malaga, Spain.
i dunt use i-tune so my suggestion is only from assumption!
MP3, AAC, RealAudio 7 and 8, WAV, MIDI, and AMR are the supported file formats for 7710. i suppose i-tune have their own file format, so you need to check that 1st.
then if i-tune works the same way as real player then it only stores the shortcut to the file and the actual music files are been stored in one folder. you simply locate the folder and use Nokia software suite to drag'n'drop to ur phone.
