Nokia have added Screen Export to their 9500 support page. From the description: "This enables you to show the screen of the communicator interface to a large audience with a compatible data projector, or other compatible projection system. The screen content is transferred to the data projector wirelessly using, for example, a Bluetooth connection."
Nokia release free Screen Export utility
slitchfield wrote:Nokia have added Screen Export to their 9500 support page. From the description: "This enables you to show the screen of the communicator interface to a large audience with a compatible data projector, or other compatible projection system. The screen content is transferred to the data projector wirelessly using, for example, a Bluetooth connection."
Hello, it's there for the 9300, as well:
http://www.nokia.com/nokia/0,8764,65019,00.html
- Jim
�t doesn't matter which one you install. The 9500 and 9300 use the exact same OS/UI. So, any application that works on the 9500 is guaranteed to also work on the 9300.
Raven wrote:�t doesn't matter which one you install. The 9500 and 9300 use the exact same OS/UI. So, any application that works on the 9500 is guaranteed to also work on the 9300.
So, will a Wi-Fi sniffer work on the 9300? Or a photo app? I don't think so .... 😉
praefectus wrote:So, will a Wi-Fi sniffer work on the 9300? Or a photo app? I don't think so .... 😉
I do. 😉 That is, it will run on the 9300, but obviously not function properly as the 9300 doesn't have WLAN nor a camera.
