I got a full blackballer version
it works fine for incoming calls
incoming sms gets the new message tone and "1 new message" prompt. If I then show the message, it gets displayed very briefly then goes straight into the blackballer logs. I got the "mute sms/mms" option set.
in theory when an sms comes in from someone in the blacklist, nothing should happen (no new sms tone/prompt) and should go straight into blackballer logs.
are there any other similar apps out there that can filter specific numbers for incoming sms?
I cant get it to work either. Using advanced call manager instead. I wanted to use the block sms feature too.... grrr which ACM doesnt have.
Chris
Sorry Chris, you say your using ACM, but then say it cant block pre-defined sms?
does this just block calls then?
btw.
blackballer DOES seem to work....sometimes!
defeats the object really!
cant seem to pinpoint exactly when it does/doesnt work.
I think it may have something to do when you change profile/theme.
i find straight after a re-boot, it does seem to do the job, but not certain about it yet.
