Drivers for Nokia 6630 USB on XP Pro
3 replies · 11,857 views · Started 28 April 2005
Hi all, am new here as of now!
I have a problem where the Drivers for the USB will not load onto my PC. I am running a borrowed version of XP Pro & have the prod. key. What's the prob? I've tried uninstalling/reinstalling, coping drivers etc.
Works fine on my work PC but alas am not "allowed" to have the software on it!
PLEEEEASE HEEEEELP ME!
Hard to say without knowing what the problem is. Try uninstalling PC Suite and then also the "Nokia Connectivity Cable" drivers from Control Panel.
Then get the latest PC Suite package (6.5.12) from http://www.nokia.com/pcsuite and install it (it will also install the latest DKU-2 drivers). Note that the PC Suite 6.5 has just been updated from 6.5.10 to 6.5.12, so if you already have a version, it is probably the older 6.5.
If that doesn't help, it might be a good idea to say what "will not load" means, exactly, in your case. What happens? What error messages do you see, etc.?
