Upgrade success!!
4 replies · 2,266 views · Started 28 April 2005
Successfully upgrade my X to the latest version!!
But when I restart my phone, I found nothings change except the version number change to 1.98.5.2. As my experience of upgrade Siemens SX1, all data in Drive C: will be clear off. Shall I format my phone? And how to do it? :con? :con?
update success here as well (after the site came back up) - yes, from what i have read you should reformat your phone by powering down, then hold the 5 key and press/release the power button again (to start it up). you will be given a multi-language screen that says something to the effect of "do you really want to clear the memory" - hit the left soft key to confirm and after a little bit your phone will restart. then you are done 😊
Just to confirm this - the Sendo update procedure will NOT destroy any of the data stored on the phone's C: drive; however, it is recommended that you re-format the phone after an upgrade anyway. You do this by holding down the 5 key while restarting the phone.
