sms 9500
2 replies · 1,702 views · Started 29 April 2005
My friends
as to make to receive one sms in 9500?
which door that arrives SMS?
tank you
ps.: sorry language, I am Brazilian 😃
I'm not absolutely sure what you are asking for, but...
If there is an SMS message center number on the SIM card, the phone picks it up and uses it automatically. Arriving SMS messages end up in the "Inbox" of the "Messaging" app on the phone. When you send messages, they are sent to the message center.
The message center you can change in the "Control panel" application (> Messaging > Text message).
On the inside display, when you open the "Messaging" application, you can also hit the "Menu" key and in the "Receive" menu open "SIM messages" to see messages received and stored on the SIM card (if any).
Now, if you are really writing an application (C++ or Java) and asking about port numbers, etc. (you used the term "door", so I'm not really sure), then try the development forums (but you need to explain more about what you are really asking about): http://www.allaboutsymbian.com/forum//forum/f/6/
thanks
I am developing an application in Personal Profile!
The API of the PP does not give to support the SMS!
As it would make to capture the sent SMS
[]`s
Felipe
S�o Paulo / Brazil
