OK i just bought a headset for my 6620 an aftermarket one and the volume is very low compared to my past nokia's. When searching on ebay, all i found was headsets that go around your ear and sticks out about 2in, but i've been eyeing the 7610 oem earpiece which is just a ear bud that hangs down. Can i buy the 7610 headset and it works with my 6620 or is the adapter different? Is there a reason they made the oem nokia earpiece different due to the mono and sterio output? Whats does that mean, can i buy headphones for my 6620 cuz its not mono, and hear music from both sides? OR DO ALL 6620 HEADSETS SOUND LOW?
Headset for 6620
They don't all sound low. I'm using a Motorola HS850 with mine, and it works beautifully. Loud, clear, comfortable, and compact when not in use.
