ZingMagic, the brains behind Chess on the P800 and P900, are now publishing and selling their own applications from the ZingMagic Website. Using a custom web solution from Mobrio, they have all their applciations on-line, and you can purchase them from inside each application. Long term Psion fans will also be glad to hear that all of their EPOC back catalogue is now available as freeware from the same site.
ZingMagic Switches to Self Publishing and Release Older Titles As Freeware
Erm, the whole point of the Mobrio solution used is that its not a custom solution, any more than the AAS site is customized given it is able to accept the content of this comment - which customizes it. Its fundamentally a blogging solution, each page on the site is a blog entry (post). The fact we can control it + put our own content in a post is about as custom as it gets.
In short you can build corporate web sites from the Mobrio blogging solution.... not top end all singing all dancing ones, but ones good enough for the vast majority of SME's and individuals..
There we go, I stand corrected! Thanks!
