Hey guys,
when ever i try sending myself files frm my pc to mobile or mobile to mobile via bluetooth i cant save them...when i click on options and save it gets stuck on "saving" and nothing happends...
any help??
Thanks!
Hey guys,
any help??
Thanks!
supersam wrote:Hey guys,when ever i try sending myself files frm my pc to mobile or mobile to mobile via bluetooth i cant save them...when i click on options and save it gets stuck on "saving" and nothing happends...
any help??
Thanks!
Make the pc or other mobiles as "AUTHORISED" and all the files you received will be saved directly in your inbox
any help??
Thanks!
Are you saving files to phone or memory card?
If usin card then it may not be inserted properly (menthioned in a previous thread), it may not be formatted correctly or may have some other problem with it.
If this is not the problem then the file may be corrupted in some way or may be so large that it takes a while to save.
If it has been sent it to your phone then obviously it is in ya messeges inbox, correct? Can it be opened from there without saving?
Thanks for your help guys!
it jus got fixed by itself..
