After works of days and nights, we've found the way to load themes on sx1,maybe it's unofficial but it really works and changes everything like the themes on nokia series 60. if you just wonder how, please contact from msn messenger by [email][email protected][/email] or from icq by 164006078
Sx1 Theme At Last
Any reason why you couldn't just post it here...?
because it's too complex to post all the stuff and info to here and talking on msn messenger makes it easier to understand for people.
Can you use same themes as is used in Nokia 6600? Does it change also the background of the menu?
Its been possible to do themes on the SX1 all along - the catch is that it invariably means messing about with the firmware.
Until the unlikely firmware update comes along that supports themes, then its not practical.
well it's not a new news guys, we know how to enable/change themes since septembre 2004, and now not only the upper part, we can change network/battery indicators, splashscreen (the startup eye), add SX1 alarm tone (wav or mid) change menu folders icons and a lot of other things,
this is part illegal since this is done by patching the firmware, check out http://www.siemens-mobiles.org there's a patch generator there, plus tutorials for newbies and also an newbie FW (already patched FW just need to update your phone with and you're done)
it's not complicated as mentioned above, just need to understand how to do it and afterwards it's simple and easy to understand
