Who ever connect Infrared 7650 -> PC to Internet(GPRS) .
2 replies · 1,938 views · Started 02 November 2002
I can't set my PC dail GPRS through my 7650 ?
Create new connection
set Moden on infrared port (windows xp pro)
set number *99***# <-- GPRS number AIS
and dail ...
opening port and
error 633 the modem is already in use or is not confiured properly
i check all program already but still same...
I'm using my 7650 on GPRS over IR at the moment.
I use:
*99# as phone number.
Security options are set to custom and have just 'PAP' selected.
Every thing else is n the default setting.
In 'Nokia Mobile Options' you need 'general.t-mobile.uk' as your GPRS APN.
Best
Will
[quote="xpojx"]
and dail ...
opening port and
[/quote]
Try this:
> connectivity > modem > options > connect
And, also, u must have "Nokia 7650" in the modem tabs, and not just "Infrared modem"
Go in "C:\Windows\inf", copy "Nokia7650IrDA" .inf e .PNF (for the IrDA connection) or "n7650BT" .inf e -PNF (for the Bluetooth connection) everywhere on your pc (for expmple C:\a)
Now go in System and underline "Infrared Modem", then click on "Update drivers" and select the folder you've just created (C:\a)
Choose Nokia 7650 and reboot the system.
Here you go! :P
Ps: my pc is italian and also my mobile, so ...excuse me for the mystakes ...if any! 😉
ciao,
m a r c o | i
