6630 starting off....(for those who like to help)
7 replies · 2,206 views · Started 01 May 2005
I have just got a 6630 on O2 (if that makes any difference) would like to know which of the pre-installed programmes I can delete for space, or should because theyre c*@p.
Also (and I promise I have searched for the answer) to the following two questions;
How do I change the operator Logo to clear/another pic/ transparent, got as far as downloading FExplorer and without an Idiots guide have hit my limit to understanding how to do it!
And I dont need to se it as an MP3 player due to the expensive purchase of an iPOD but use MP3s as ringtones, do i need to compress them as they seem to big large files (if so how or what programme?) and if not then that kinda answers that one!
Cheers for your help and any other advice about things to add/remove/buy or do would be greatly received!
Ben 😃
Wirelessly posted (NOKIA 6630: Nokia6630/1.0 (2.39.151) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
U cant delete ANY of the apps that r built into the handset! U can format the mmc to get rid of the stuff on that! Also u can goto default file manager and look in the folders and delete any pics/sounds o2 have put on! Also in messages u can delete the TEMPLATES altho they dnt realy take up to much mem! About ur logo question, find a logo/image u want and open fexplorer, C: is fone mem, E: is mmc mem so goto the logo/image u want as a logo then highlite it and press options/file/set as op logo! Fone will restart! To replace with a dif logo/pic repeat above! To get ur default logo bak open fexplorer and goto C:/system/apps/phone/oplogo and delete the file in there and then reboot handset!
i have one problem whereby my messages automatically transfer to memory card.i can't read messages . I need you guys help.I'm using N-gage QD
prakash wrote:i have one problem whereby my messages automatically transfer to memory card.i can't read messages . I need you guys help.I'm using N-gage QD
Goto messages/options/other and select fone mem for messages (if u have that option)
prakash wrote:i don't have that option.i'm using N-gage QD .
Then i dnt know how to sort it mate! Im realy not an n-gage person!
is that anyway to move it back my message from memory card to device memory :frown:
then why are u asking ur question on the 6630, 668x forum???
