help me find 6620 clear zip skin case?
1 replies · 2,012 views · Started 02 May 2005
Please help me find this, i cant find one anywhere not even ebay. 😡 Will the 6600 clear skin case fit my 6620 please help. PLEASE POST UP LINK
hi all.
just to let u all know, after reading all these posts I was able to fix my crashed phone - 6600 - with the -green-*-3- action. took out battery first, reinserted, held those keys whilst turning on until got 'formatting' message with scrolling bar across screen as it formatted. lost all info and settings, but no problem getting to my serv provider here in australia (Telstra telcom). phone works fine, will back up ph memmory to card memory more often. I haven't tried other boots commands, I figure if it works, it's all good. sems to me that so many others are having problems after installing 3rd party software ... maybe that's the lesson.
I was looking at installing the eggtimer to enlarge the clock show on the fron, but I don't know if I will bother now.... maybe not worth the risk. yep, phone was 2 weeks out of warranty... Nokia wanted min $50 aus to probably $120-140... saved heaps. Thanks Ghostdog and others...
anyway, i don't use bluetooth, do not connect my phone to pc and only use a mem card reader to copy pics n stuff.
for anyone intending to buy one, the thing I hated was that the software to handle pics and movies was only a trial version, and wouldn't handle the .3pg type of movies it made anyway, and it took a bit of hunting on the net to find a software that would, and can't convert it into other formats yet, and friends can't all read these formats either.
the other thing was that it has this huge screen and displays the time/date so small - what a waste. other than that, it works for what i wanted, which is to take pics on site for customers and my files and to make video and to use voice recorder...
again thanks for all helping.
