Help: Security and Certificate
0 replies · 4,280 views · Started 02 May 2005
Dear All:
is anybody able to help me? I'm trying to install a digital certificate on my brand new 9500 to connect to the WLAN of my Dept. and the following happens.
1. When I try to install the certificate that is supposed to state that the Dept. is a trusted authority (which I try to install inside the "Other" tab of the Control Panel -> Security -> Certificate Manager section) I get the following message:
"System: Operation is not supported"
2. When, instead, I try at least to install my personal certificate (insede the "User" tab of the same section) I'm first asked for the certificate password (which I know), then for the "current key store password", which I don't know because it is the one that came out from the factory, and I haven't found any clue of it on the web.
Any help about either issues?
Thanks a lot!
