I've got a 6630 and 'm having problems removing some programs using the App Manager. It just freezes on the screen with the removing bar.
Any ideas?
Any ideas?
Check if the application is still active or running in the background. Turn it off before uninstalling, if you still haven't.
Well I tried all sorts of things, like starting in safe mode, manually deleting programs with FExplorer.
In the end I just formated the memory card and it seems to be working now. I hope this wont be happening on a regular basis 😊
some files may still b on c:\
check it out
Wirelessly posted (NOKIA 6630: Nokia6630/1.0 (2.39.151) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
If it hapens again just format fone! In idle mode *#7370# that mite sort the prob, altho u mite want to bak up fone mem to mmc coz it will delete ALL the things U put on fone memory!
Mr Gar wrote:Well I tried all sorts of things, like starting in safe mode, manually deleting programs with FExplorer.In the end I just formated the memory card and it seems to be working now. I hope this wont be happening on a regular basis 😊
Don't try to manually delete anyting! I screwed up mine ex 7610 that way so thet I had to carry it to the Service center to put new software.
