anyone know how to put your own ringtones into the QD?
N-Gage Ringtones
The wise-a** answer to your question would just be: "Yes". 😉
Anyway, there are plenty of ways. Here are some...
Send them (.wav, .mid or .amr files, for example) from a PC using Bluetooth (then in the phone Inbox open the message with the tone and save it).
Use a PC-based card-reader to put them in the /Sounds/Digital directory (or folder, if you prefer to call it that) on the memory card.
Use the PC Suite (http://www.n-gage.com/en-R1/support/Software/pcsuite.htm) software with Bluetooth to put the files on either the memory card or in the phone memory (/Nokia/Sounds/Digital directory).
You can also install FExplorer (http://www.gosymbian.com/) app on the phone, and use it to copy files around (the C-drive you see there corresponds to the phone memory, E-drive is the memory card, D-drive is a small memory drive for application temporary data and the Z-drive is read-only and contains the phone operating system and built-in apps).
If you have web server, you can also put your ringtones and access them with the phone's browser over the network.
And if you have set up the phone to access email, you can also send them as email attachments to that email address you've set up the phone to use.
thanks alot ...that was a big help....
another gr8 cheap way to put real muxic ringtones on the n-gage its record them from the radio!!!
:d it take a little bit to get song right or the song you want but it works just fine and i you set a pop station you get ringtones that no one else have yet from new songs and sh***
