6630 Not Booting
2 replies · 1,809 views · Started 05 May 2005
hi guys / gals,
my 6630 hangs with a white screen during switching on the phone. i have to take out the battery to switch it off. Green * 3 also does not start.
advice
Binil
This seems a common fault in 6630 especially those using early firmware.
Only fix is to get phone flashed.
You will have to take phone to nokia service centre/retail outlet or send it back to network provder to have this done.
All stored info on phone will be wiped and new software installed.
This, i have been told, should fix the problem.
