can anyone help?i m livin in singapore n the oplayo sw i dl cant seems to get mi into any video streamin.the teletext sw s well s the mirc sw all don work.anyone pls help?thx a lot
oplayo to work in singapore
Do you get errors? What kind of errors?
it jus sort of get stucks after connecting n the application jus close by itself.for the irc sw,it jus fails to connect into the server no matter wat.the teletet one oso face the same prob. 😞 the webviewer oso cant get it to work.thx if anyone can help.
Are u using an WAP access point?
nope.its a gprs connection.few frens of mine try using different mobile service provider networks oso cant get thru.
Using GPRS does not mean you dont have a WAP access point! Some GPRS packages are only for WAP! Try to make sure you have access to the FULL Internet! Seems like this is your problem!
its gprs alrite cos when i start the oplayo program,it blets mi select btween gprs or mms access points.so it has to b gprs.pardon mi if i m wrong n kindly help mi to solve this prob.or is there anyway to dl the video clips thru pc n transfer to my 7650 thru bluetooth or ir?thz for yr help...
Yes I understand it is GPRS but there are two types of GPRS! GRPS WAP and GPRS Internet. The one is filtered to use ONLY WAP and the other is for the full internet!
However, I havent used Oplayo that much and my phone is at the NSC! However, it is possible to download the and send them to your phone! For more details maybe someone else can help you on this!
I STILL think that your problem is you GPRS access point allowing only WAP and not Full Internet Access 😊
thx pal.i really wan to get hold of some videos to dl into my fone.thx again pal.
where can i download oplayo ??
http://www.oplayo.com/downloads/
Obvious I guess!
for some reason when i get to the agree/disagree Software License for Oplayer mobile video player i press agree and it does not transfer the file..
Must be a problem with the web page! Try to use another browser instead of IE!
If you are using M1, you should apply MobileNet to access the video!!!!!
thx,but wat if i m using singtel network?s at shd i apply for?thx for yr help...
[quote="snkboy"]thx,but wat if i m using singtel network?s at shd i apply for?thx for yr help...[/quote]
Hmm. For SingTel Mobile, i think you would have to subscribe for its VAS, MobileOffice.
Basically you can enquire SingTel Mobile by calling 1626, and press 3 for e-ideas enquires.
Hope this helps. 😉
really?thx pal,i try later.hope it works.thx again......
[quote="snkboy"]really?thx pal,i try later.hope it works.thx again......[/quote]
😉 You may want to keep us updated. So we will be able to help you some how. 😃
Eerrr..anyone know where to get the movie..so that i can download from my Pc and then infra to my 7650 😃
