profiles problem - 3650
2 replies · 2,199 views · Started 06 May 2005
hi all!
please, need ur help, guys!
not sure y, but my 'general' profile is not running properly. i have a wav sound as a ringtone, and inside "personalize profile" it reads okay(volume to max). but when the phone rings, it is really silent, can barely hear the tone...
the other profiles with the same ringtone r working okay...
please, someone tell me where the problem is, and wut to do!
:icon14: appreciate,
!�K�
Have you got the ring style on ascend?? That might be a simple cause, otherwise i'v never heard such a problem or had one on my old 3650.
Duke
Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
I don't think this is one of the problem. You should try check all setting that you might miss it..
