Hi. Anyone knows how to copy the file Contacts.cdb?
I must send it to a software house to work on a 9500/Mac contacts converter.
It's not possible to copy it because it's on Z drive, do you have any solutions?
Thank you,
Thank you,
fuoriporta wrote:Hi. Anyone knows how to copy the file Contacts.cdb?I must send it to a software house to work on a 9500/Mac contacts converter.
Thank you,
Contacts.cdb is held on the c: the path is communicator\system\data\contacts.cdb
As far as I am aware you cannot copy it bcause it is always in use, what you can do, is make a new database on the memorycard, and then copy all the contacts to this new database and then copy this new database.
Either that or you can do a backup on the memory card and the file contacts.cdb in the backup folder will be available to be copied anuwhere you need.
HTH
P.
thank you. done,
