links to oplyo streamed videos
7 replies · 2,024 views · Started 02 November 2002
can anyone pls provide mi wif any links s to dl some video clips so tt i can ir into my fone n watch them?thx alot for u ppl help n btw,tis site rocks.it actually helps mi to get to knows tt lots of ppl r interseted in mobile fone stuffs.keep it up. :P
Welcome to our forum!
You can get some links of Oplayo content here!
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=2932&highlight=oplayo
However, please in the future try to search the forum because most of the times your question will be already answered! Use the search function on the top of the page! If you cant find anything we will be more than happy to help you!
like i said i cannot download from there i dunno why ...
and what about the software that shows screensavers..?
the few url i type into my pc don seems to work.url like www.saunalahti.fi/behemoth/permanent.mvp doesnt work.it jus tels mi tt i cant view the xml page.n i cant get the streamed video usin my oplayo sw.wat can i do ?
There are other links that might work! There will be ppl that will post links for you probably! I dont know anyome sorry 😊
no prob pal,u do help alot.thx.i got some sw which i purchase from net for the 7650,feel free to contact mi n i wil e mail them to u.
[quote="snkboy"]the few url i type into my pc don seems to work.url like www.saunalahti.fi/behemoth/permanent.mvp doesnt work.it jus tels mi tt i cant view the xml page.n i cant get the streamed video usin my oplayo sw.wat can i do ?[/quote]
Internet explorer doesn't want you to view xml-pages. If you download the .mvp and open it with notepad, you'll see it is a working playlist.
As a matter of fact, if you get that "can't view xml page" with IE it means that the link is correct and the server is up. 😉
** Magic **
