is ther any way to save a tx msg to the mmc card. i just got a goboy rom via bluetooth and the files too big to remain in my inbox, is there a way to transfer it straight to mmc card??
txt msg to mmc
In the Messaging app options there's a setting labeled "Memory in use" which' value can be "phone memory" or "memory card".
If this doesnt give you the option to copy from Phone to mmc you can do it manually using FExplorer.
Go to C:/system/mail and search the numbered folders for the file,then select 'copy' and then 'paste' to where ever you like,e:/ is the mmc. 😊
