Memory
3 replies · 1,226 views · Started 02 November 2002
Check my maths but these figures don't add up:
4kb Calendar
91kb Contacts
180b Documents
38 Messages
745kb Images
20kb Sounds files
193kb Applications
Total about 1091kb
Plus 1025kb for apps/games
That makes 2116kb I used but it says I've used 3158kb, where's all the other memory gone?
Wish you could upgrade the memory, 4Mb is just not enought at all. 😃
look for an application which was not installed and waiting at the bottom of Application Manager's list. I had the same problem and found that I forgot to remove one of the programs which I could not install...
normaly between 650-730kb. hidden-system-files are also in the C,what is your memory.
so u have to add.them to the normaly kb.of memory too.
If u now maybe have install e-profile,screensaver from psiLOC the hidden file grow a small bit more up.
(for reasons like:
5 different images for each profile as background copy 5 times the image as bmb-file-format to the hidden files.)
1mb.is quite large,but 750kb. is normaly.(even if u buy it,they was there)
S�mi
