Debrand Nokia 6600?
1 replies · 4,814 views · Started 07 May 2005
i recently purchased a nokia 6600 on ebay. it was not simlocked to tmobile but it does have the annoying branding (splashscreens, startup screens, shortcuts, goto links, screensavers... etc) i was wondering if there is anyway to delete them...
are the files extra unessersary files that need to be deleted or are they files that you actually need and within the file contains the tmobile things... i dunno
i have fexplorer and have found a few suspicous files but im really not sure... obviously ill back them up before i try anything... thats if i try anything... any ideas?
If its on the ROM, then you can't get rid of it 😞. If it isnt, and you know where it is, then download FExplorer, and delete them. I know how to get rid of the start up screen, 'Tools', 'Settings', 'General', 'Welcome note or logo', then select either options.
