hey,
im getting the n-gage system eror message whenever i try to access anything on my n-gage...i can only make and receive calls...nothing else works.....
also, when i try putting the mp3 player or radio., the phone reboots...
sometimes...on leaving idle for a while, the phone shows 'insert sim card' where i have to reboot manually...
what do i do?
do i have to format?
while that 73710 or whatever number be useful?
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0 UP.Link/6.3.0.0.0)
N/A wrote:*#7370#
Do you have a mmc in your device.Try using it wit no mmc.It happened to me once. Had to erase everything on the mmc via pc.If that doesnt work format your device.
id rather save my contacts to the sim and format the fone(less memory to deal with) ant thats usually where the problems are anyway
Squizter wrote:Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0 UP.Link/6.3.0.0.0)Do you have a mmc in your device.Try using it wit no mmc.It happened to me once. Had to erase everything on the mmc via pc.If that doesnt work format your device.
I try remove my mmc card from device and using *#7370# but still same , did you any idea .......... thank you
elden79 wrote:I try remove my mmc card from device and using *#7370# but still same , did you any idea .......... thank you
Hi all (first post WOOT)
i have the same problem and was just wandering if there is anyway to get your messages and such off the fone memory? or am i completely stuffed and have to reset?
cheers alll
KopyKat
